285 70 17
i want to put 285 70 17 on my stock 08 rubicon. i test fitted them and they rubbed. if i was to put a teratrek leveling kit in would those tires now fit??
Stock wheels -- they probably rub at full turn; Adjust the steering stops and possibly trim/remove the front air dam. See link in signature below for a picture of the steering stops. A leveling kit won't fix it.
Aftermarket wheels with more back-spacing-- they probably rub at full articulation on the fenders; Add bump stops, modify fenders, and similar. A typical leveling kit won't fix it, but it the rub will happen less often (because of more up-travel before hitting the bump stops).
I just cut the "wings" off the front air dam and put two small washers on my steering stops. My 275/70R18's are the same as a 33X11. I have zero issues at full flex and full lock. I have a very mild 2" coil spring lift.
