Is the 3rd brake light and ......
Yes and No. The back of the third light is molded with the spare tire carrier, so yest. Only a little no because you can unscrew the light plate as if you wanted to change out the bulbs or wiring, so no. But technically yes. The third brake light is molded with the factory spare.
The rear portion (with the lens and functional parts) of the CHMSL is plastic and can be mounted to other things. For instance, it can be moved to the tire carrier of the LōD rear bumper with the available bolt-on bracket.
