4 door Rubi Rails on 2 door?
Has anybody modified some stock 4 door Rubi rails to fit their 2 door? The 4 door rails seem to be more plentiful used. I don't know when I'll be able to get some (money), but if I come across a 4 door pair, I'd like to know if I could use them on my 2 door. Any suggestions, pics appreciated. Thanks!
if you have a welder or know a good one, you can pretty much mod anything to make it work. It would just depend on how good of a deal you could get on the 4dr one.....right?
i was actually researching this myself a couple weeks ago...
from what I read through searching and sending out pm's is that the rails are exactly the same just the 4-dr is longer and has an extra bracket for support.
So 4 door rails can be cut and mounted onto a 2dr. You will probably have to cut the rail anyway to make clearance for a bigger tire so instead of trimming a little bit (if you had 2dr rails) you will need to cut off the extra length from the 4dr. Just make sure you measure twice
and thanks BBirish for the helpful info............
