ABS & ESB lights are on
Hi guys. My ABS and ESb lights came on along with the traction control graffic. The dealer has had my JK for 3 going on 4 days, and cannot find the issue. Has anyone had this issue before?
Cut wire to the speed sensor and/or a bad speed sensor. Keep spares, works all the time.
Reviving this Thread.....
Okay, so I had the same issue... log broke my speed sensor on the driver's side. I just replaced it, and I am still gettting the codes... Is there a way I have to reset the system so the code goes away, or should it go away on its own if everything is good? |
This same thing happened to me as well when my rig was still pretty new. After replacing a shit load of things, including the computer, they finally figured out it was a bad wire in a harness somewhere hard to get to. They had all kinds of fun with that one....:crazyeyes:
Oh.......and not to hijack this thread....(I've had it posted in the diagnostics sticky with no response) but....
Been having the engine light come on and off for a week or so. Decided to check the code. Does anybody know what this one means or where this sensor is located.....tranny? exhaust?...:dontknow2: P0057 - O2 Sensor 2/2 Heater Circuit Low Thanks..... |
Originally Posted by Hkx3
(Post 1563082)
Had it happen on my 09.
Turned out to be a wire cut under the front bumper. It is part of the loom that goes to the foglights. Red and Green wires I believe. Basically a stick had gone up in there and sliced the wire cleanly. Killed ABS ESP Traction Control everything. I found it by laying on my back in the garage tracing wires from the wheel sensors. Fixed the wires, boom! back in the game. My cruise control would not work either. Apparently those systems will disable cruise. Reconnected - tightly/cleanly - and I was back in the game. I guess even if you're fully comfortable w/ your own potential to err, never assume the 'experts' put it together properly to begin with... |
Bringing this back... I installed my lift, welded on c-gussets (took the axle out to weld them up), new Synergy front and rear track bar, tie rod bar, and drag link as well as new front bearings and speed sensors, new brakes (rotors, pads, stainless steel lines, fluid)
My ABS, ESB/BAS and traction control lights are on. Does anyone know what to look at... It's not throwing any codes. I checked to be sure all the connection that we disconnected, we're reconnected. Is there anything else I should check? |
Originally Posted by darkknight1999
(Post 3972100)
My ABS, ESB/BAS and traction control lights are on. Does anyone know what to look at... It's not throwing any codes. I checked to be sure all the connection that we disconnected, we're reconnected. Is there anything else I should check? BTW: It probably is throwing a code, it's just that most code readers and the dash don't display ABS codes. A dealer could tell you in a few minutes which sensor is acting up. But usually a careful visual inspection is sufficient to figure it out. |
(Post 3972162)
Visually inspect the wires to each of the wheel sensors. You're looking for any evidence that one might have gotten crushed. If you find a problem, repair damaged wire (splicing is okay) and route it so it doesn't get crushed.
BTW: It probably is throwing a code, it's just that most code readers and the dash don't display ABS codes. A dealer could tell you in a few minutes which sensor is acting up. But usually a careful visual inspection is sufficient to figure it out. I'll inspect the wires again in the back. Is there anything else I should look at? |
Well we double checked everything... took it for a drive and the lights all went out. ;) Works for me!
So to recap for anyone that reads this: In the process of installing my lift I forgot to disconnect the Negative side of the battery Disconnected both front ABS sensors (breaking one) to install new wheel bearings Installed new wheel bearings and ABS sensors ABS, ESB and traction lights came on when I turned the jeep on to check a few things. We finished installing the lift. Took the Jeep for a ride and within a mile all the light went out. Lesson is don't forget to disconnect your battery... lol :rotflmao2: |
