Any harm from mixing grease?
Store was out of Red N Tacky. Got some green marine grease which is also NGLI approved. Is there any harm in using two different types of grease in a joint?
nope......
Grease compatibility is a whole subject in itself.
Mixing incompatible greases can destroy the item you are trying to preserve. I know because I've seen it happen on aircraft. Google "Grease Compatibility". You will see lots of info and compatibility charts. |
greases are made up of different properties. They break down differently as well. I would not recommend mixing.
Great I already mixed the two. Should I try and flush it out with red and tacky?
Do some homework.
Read the packages the two greases came in, then look them up on a "Grease Compatibility Chart". |
Originally Posted by ronjenx
(Post 1736862)
Do some homework.
Originally Posted by Hellbound13
(Post 1736866)
OK ill check it out. I guess Ill have to remove it from the grease gun so either way that grease canister is done once I remove it.
(Post 1736869)
Don't jump to a conclusion. Homework first.:yup:
(Post 1736870)
No Im saying it came in a cylinder tube. I can't read the ingredients without removing it from the gun..
