Any harm from mixing grease?
Old 06-19-2010, 01:53 PM
Hellbound13's Avatar
Default Any harm from mixing grease?
Store was out of Red N Tacky. Got some green marine grease which is also NGLI approved. Is there any harm in using two different types of grease in a joint?
Old 06-19-2010, 03:46 PM
rmdchewie's Avatar
nope......
Old 06-19-2010, 04:07 PM
ronjenx's Avatar
Grease compatibility is a whole subject in itself.
Mixing incompatible greases can destroy the item you are trying to preserve. I know because I've seen it happen on aircraft.
Google "Grease Compatibility".
You will see lots of info and compatibility charts.
Old 06-19-2010, 04:14 PM
Serg5000's Avatar
greases are made up of different properties. They break down differently as well. I would not recommend mixing.
Old 06-19-2010, 04:27 PM
Great I already mixed the two. Should I try and flush it out with red and tacky?
Old 06-19-2010, 04:30 PM
ronjenx's Avatar
Do some homework.
Read the packages the two greases came in, then look them up on a "Grease Compatibility Chart".
Old 06-19-2010, 04:33 PM
Originally Posted by ronjenx
Do some homework.
OK ill check it out. I guess Ill have to remove it from the grease gun so either way that grease canister is done once I remove it.
Old 06-19-2010, 04:36 PM
ronjenx's Avatar
Don't jump to a conclusion. Homework first.
Old 06-19-2010, 04:37 PM
No Im saying it came in a cylinder tube. I can't read the ingredients without removing it from the gun..
Old 06-19-2010, 04:40 PM
ronjenx's Avatar
Look it up on the internet.
Quick Reply: Any harm from mixing grease?
