Attention 2012 owners!
Old Aug 29, 2011 | 10:56 AM
bigljking's Avatar
Default Attention 2012 owners!
Those of you with 2012s hold of on changing your gear ratios. Apparently the 2012s have a new trans controller that puts the jeep into a limp mode if it senses a change in the ratio. Just received an email from AEV highlighting this issue. They said a Jeep dealer cannot over ride this and they are working on adding a fix into a new procal module.
Old Aug 29, 2011 | 10:59 AM
Bingbola's Avatar
What does limp mode mean?
Old Aug 29, 2011 | 11:08 AM
bigljking's Avatar
My guess would be that it will only allow you to drive at a slow speed and cut engine power. Just picture traction control on permanently killing power and speed. If it's involving the trans then probably won't allow you out of first or second gear.
Old Aug 29, 2011 | 11:09 AM
WhosUrBuddiee's Avatar
Limp mode means your vehicle has detected a serious problem and has to protect the engine. Limits RPMs to under 1500 until problem is corrected.
Old Aug 29, 2011 | 11:14 AM
JKred's Avatar
Yep, often you can't even get rolling. It will completely incapacitate the jeep.
Old Aug 29, 2011 | 11:16 AM
Rockroaster's Avatar
Yet another reason I'm glad I didn't switch to a new one!
Old Aug 29, 2011 | 11:23 AM
CrazyCasey's Avatar
= LIMP MODE
Old Aug 29, 2011 | 11:28 AM
Mredkilledmyz's Avatar
Update:
I just received an email from AEV regarding this issue and they say they have a fix and are currently working on integrating it into their Pro-Cal module.
They expect to roll out the updated Pro-Cal Modules by end of September.
Old Aug 29, 2011 | 11:30 AM
Originally Posted by Mredkilledmyz
Update:
Damn that is fast.
Old Aug 29, 2011 | 11:31 AM
dgnr8's Avatar
Originally Posted by CrazyCasey
= LIMP MODE
hahaha i've been in limp mode once or twice
