Axle C bent
Old 02-15-2013, 05:13 AM
Dkjk's Avatar
Default Axle C bent
My passenger side axle C is bent in about 4 degrees or so. Anyone one have an low cost idea on how to relieve that?
Old 02-15-2013, 05:40 AM
Tonka_yellow's Avatar
Off set ball joints. What tire size do you run and you should look into c gussets
Old 02-15-2013, 07:17 AM
Dkjk's Avatar
Only 33". I've not been concerned about c gussets because I haven't heard if anyone having issues until 35" or bigger. Ball joints are tight and in good condition.
Old 02-15-2013, 10:54 AM
hypeiv's Avatar
He was saying you can buy a set of ball joins that are offset to correct the bend... but then you should also get gussets to prevent it from bending any more.
Old 02-15-2013, 11:00 AM
Sorry, what I ment was you can buy off set ball joints. That will fix the problem. Get some c gussets to stop the problem from happening again
Old 02-15-2013, 11:09 AM
Dkjk's Avatar
Oh ok! Got it. Where can I find some offset ball joints?
Old 02-15-2013, 11:20 AM
http://www.jcwhitney.com/2007-2012-j...07-2012j1.jcwx
Old 02-15-2013, 01:07 PM
Dkjk's Avatar
Thank you!
Quick Reply: Axle C bent
