Bad Noises......help
Hi all. I'm hoping that someone here can help me identify some not so nice noises that I am getting from under the jeep. I'm getting sounds that I can only describe as a popping and clicking.
They occur mainly while starting from a stop (while it is under load) and while the wheels are moving very slowly, and sometimes at very low speed corners, after starting and at higher speeds there is no problem. I've searched a bunch and asked several opinions but am still not exactly sure where this is coming from. From what i've heard/read it sounds like it could be anything from driveshaft binding (increased angle from lift) , trackbars (front and rear), front sway bar (which I have been having problems with recently). I'm not too sure if which it is if any. This all started to happen after I installed my 2.5" TF coil lift and spidertrax spacers.
Any help would be much appreciated!!
edit: i think this might be better in the modified section, please move if necessary mods. thanks
