On board air
Old Sep 27, 2011 | 04:20 PM
Brandon1024's Avatar
Default On board air
I was wondering if I could you a compressor for a train horn to air up my tires too...
h t t p://www.hornblasters.com/products/details.php?i=caboose-228-air-horn-kit
Old Sep 27, 2011 | 04:28 PM
RodCyn's Avatar
This is the Viair System used, and is stated to support airing up tires...
http://www.quadratec.com/products/92043_611.htm
...although it's rated only at 1.31 cfm at 0 psi.
h t t p://viaircorp.com/OffRoad/280C.html
Old Sep 27, 2011 | 04:35 PM
Im not looking to purchase just a compressor right now. I was looking to purchase a train horn and was just curious if you could use the compressor for the horn to air up
Old Sep 28, 2011 | 02:51 PM
Bump
Bump
Bump
Old Oct 2, 2011 | 08:07 PM
09GRNJK's Avatar
If you want just an air horn and the ability to air up tires, buy the kit on horn blasters with the compressor.
You can always add another quick disconnect line from the tank with the kit, that you could use to fill up your tires.
Old Oct 3, 2011 | 03:27 AM
Mikey214's Avatar
These horns and compressors run around $500 right ?
Old Oct 3, 2011 | 05:59 AM
09GRNJK's Avatar
The horns can be bought separately from the on board air kit. There are kits on hornblasters that run between 369 - 609 that include all necessary hardware for running horns.
If you are looking for a kit that you can air up your tires as well as run air horns, IMO it would be easier to add a quick disconnect line from the tank instead of adding air horns to an on board air system.
Old Oct 3, 2011 | 07:07 AM
The link to the one in the OP would that one work for the quick disconnect?
Old Oct 3, 2011 | 12:32 PM
09GRNJK's Avatar
Any kit with a tank would work with adding a quick disconnect.
