Brake Question
Old Aug 22, 2008 | 06:14 AM
dfj's Avatar
dfj
Default Brake Question
I have a 07 2 door Rubicon withh 8500 miles. When I am moving very slowly and lightly apply the brakes they groan. When I am in 4 low, it is really loud! If instead of the brake pedal I lightly pull the emergency brake – there is no noise. The dealer listened to it and said “normal”. Does your JK do this? If it is normal ok - but I would like to get your feedback before I visit the dealer again.
Thanks
Old Aug 22, 2008 | 08:59 AM
dfj's Avatar
dfj
You nailed it! That is the exact sound. Sounds like an old bed spring. Guess it is normal. Thanks!
Old Aug 22, 2008 | 11:45 AM
berg's Avatar
Normal.
I've had many cars that did it
Old Aug 22, 2008 | 12:08 PM
Yucca Patrol's Avatar
Two easy ways to fix groaning/squealing brakes caused by glazed pads:
1) Get up to 50 mph or so and hit the brakes HARD enough that the ABS kicks in. Do this three times or so.
2) Try doing the same thing in reverse (but not a 50 mph, ha!).
Most of the time, we use our brakes very lightly and this can cause the pads to "glaze". A couple cycles of hard braking will scuff the pads and eliminate the groans and squeaks.
Old Aug 23, 2008 | 12:18 AM
User 12721's Avatar
I just may try this since I am getting a super annoying chirp-chirp-chirp that goes away as soon as I lightly apply the brakes. Does this really work, and if so is it just a temporary fix? It's so bad now I was just thinking of replacing my pads. Thanks for the tip.
