Clicking Noise from the JK ?
I recently discovered a clicking noise from the JK when I accelerate from a dead stop..Normally it happens when I accelerate after it's been in park ..Happened when I was reversing out of my driveway and about to go forward
I dont get a clicking noise when I am already moving though, nor does it sound when I go over bumps..It normally clicks from a dead stop after it's been parked..I heard it click a few times when I started it up pulled it from park to reverse and revered into my garage at work
I looked underneath and nothing seems to be loose.. I am thinking it may be from the tranny?
I have 4 speed automatic 2 DR if that helps
Any thoughts?
AM
Any thoughts?
AM
I recently discovered a clicking noise from the JK when I accelerate from a dead stop..Normally it happens when I accelerate after puttng it in drive..Happens when I am reversing out of my driveway and about to go forward
I dont get a clicking noise when i am already moving though, nor does it sound when I go over bumps..It normally clicks from a dead stop after it's been parked..I heard it click a few times when I started it up and revered into my garage at work
Any thoughts?
AM
Any thoughts?
AM
If you look at the cv joints on the end of the driveshafts, do any of them have grease coming out where the rubber boots are?
It could be something in the HVAC system. My 2009 Ram just came home from a recall on it. When you cranked the truck up it would pop/click. They said it was the door that switched from fresh air to recirculate. It only popped 5/6 times after each start up. I haven't heard of this problem in Jeeps but it sounds like the same problem.
Thanks for the input
I have had that leveling kit for about 2000 miles..The jeep itself does not have more than 8000
I have ofroaded a couple of times, but nothng too severe
Ticking sound
Any thoughts?
AM
Any thoughts?
AM
This may sound dumb, but I've run into this a few times, and the most simple solution is generally the right one. Does this happen when you have the window/top down? Both my truck and my JK have a tendency to have rocks stick in the tread. When I am just taking off I notice them ticking sometimes. It's apparent with the windows down and as I speed up the wind noise drowns it out. May not be your problem but I know it's something I've run into.
Hope you find it!
