Cover With Side Steps
It's easy. Very easy. The only trick is when it comes to the straps by the rear door. That's the one I do first. Slide the clip to the end of the strap, pull hard and slide the strap between the fender and the step. Really not that bad at all.
You just have to pull on it so the clip is below the step/fender, that way it's just the strap that has to clear it. The other clips fit right through the gap between the step and body.
