Decision.
Old Aug 19, 2012 | 08:34 AM
MeatCurtains's Avatar
Default Decision.
I'm a broke Jeeper I have about 500 bucks available for some mods. Basically I'm looking back at issues I've had in the past and trying to prevent them.
Currently in my jeep I carry a few things at all times. Tire plug kit, flashlight, hand held CB, small one man tent, a tool kit, leatherman tool, a bunch of torx bits, socks, TP, water proof matches, and garbage bags. I feel the basic just what I need to make it is there. It is all pretty small stuff, easy to fit in the limited space of a 2dr. Most of these items came from ideas I got here.
I was thinking along the lines of things line on-board air systems, hi-lift jack, or maybe an inexpensive winch. Basically the must haves if you are alone and stuck or broke down.
The problems I always fought in the past were being stuck and trying to push/dig myself out, and flat tires. These two issues have me considering one of the two. I'm really on the edge of saving and just getting a good solid winch, but I really feel an OBA system would have more benefit in general. Future lockers, maybe upgrade it to run air tools or something. If I get a flat on my way to work, I can plug it, fill it and mount it on the tailgate and go.
What are your guys ideas, or do can you think of something better? I don't wheel all the time and I do a lot of driving back and fourth to work. So saving for long arm kits and dana 60 swaps wouldn't do me much good.
Old Aug 19, 2012 | 08:59 AM
Murder¹'s Avatar
Maybe a hilift & some rotopax. A winch is good but if you dont have a tree someone else or an anchor your not going to be able to pull off much.
Old Aug 19, 2012 | 09:06 AM
I made a jerry can mount for my 2011, I used it a few times when I went camping for water, out side of that nothing.
I seriously considered a hi-lift. My problem is there wouldn't be much I could do with it until I get my bumpers updated. I guess I could use it to lift a wheel and stack rocks. Off to look at mounting options and hi-lifts again.
Any other input?
Old Aug 19, 2012 | 09:19 AM
Murder¹'s Avatar
Any other input?
They have the strap for lifting your tire with the hi lift
Old Aug 19, 2012 | 09:32 AM
OK, we will take the hi-lift out of the budget, a lot of people say they are worthless and just a cool factor, but I've used them and see benefit. So it is still at 500. I'll be checking my local 4x4 shop tomorrow for a hi-lift. If not I'll order it.
I thought about things like window mount floods, but I just don't see benefit for me yet. HUGE cool factor, not that usefull.
Old Aug 19, 2012 | 10:24 AM
leonescomp's Avatar
Default Pepboys
pepboys sells both the hella 700s and 500black magic sets. the 700s are 89.99 my dad put them on his and i can attest they are bright! the black 500s are 119.99 they are bright and when off they're black cool factor but not so much a needed option. highlift jack can be used as a come a long (hand winch) with proper hooks and chains. plus the normal uses. do you have a fire extinguisher? flash light? all the small stuff is really important.
Old Aug 19, 2012 | 11:09 AM
westchester's Avatar
A 48" Hi-Lift can be strapped secure under the rear seats, so will save you purchasing specific mounting brackets. Hi-Lift also doubles as recovery jack and a manual winch if you also have chains. An electric winch can be purchased later as you'll also need to purchase a winch plate or winch bumper. OBA is a nice luxury but a modest portable air compressor works fine and a lot cheaper - get one with clips to battery, not the cigarette lighter. My dually compressor is strapped in the trunk all the times.
For budget wheeling, a length of old carpet will/might get you unstuck on soft dirt or sand, and sand tracks are cheap for the same purpose - they've worked for me on sand.
Old Aug 19, 2012 | 11:38 AM
Freewill's Avatar
OBA and some kind of manual winch. The Hi-Lift is one option for a manual winch. ARB has a manual winch but it won't double as a jack. There are lots of manual come-along types available also.
Old Aug 19, 2012 | 01:52 PM
I think I'll start with the hi-lift tomorrow, find a way to mount under the rear seat, then order an OBA system. Thanks guys. Two birds with a $500 stone
