Door hinge corrosion
Old Aug 16, 2014 | 06:58 PM
ffrogg's Avatar
Default Door hinge corrosion
Know I have seen some threads about hinge corrosion on jks but couldn't seem to find how people fixed. More so best way to clean then before painting bed lining etc. I want to just get new powder coated hinges but need to wait abit do to unforeseen brokenness. Any ideas? Thanks in advance.
Old Aug 16, 2014 | 07:01 PM
tribulation138's Avatar
I just did mine. The paint was just flaking off. The hinges are just aluminum. I stripped them, then sanded down to bare metal. 3 coats of white primer and 4 coats of black satin spray paint.
Old Aug 16, 2014 | 07:04 PM
ffrogg's Avatar
Paint has flaked off and has a white color figure I'd use Bedliner just wasn't sure how to clean the so it will stick, also I read somewhere that the doors aren't painted under hinge, haven't taken mine off yet. Where yours paint under the hinges?
Old Aug 17, 2014 | 04:30 AM
No they aren't painted under hinge. Mine even had some surface rust starting. I cleaned that area too.
Look like cryslar painted the door with hinges on and even the torx bolts
