Dry pavement and 4WD
I know it is best to use your 4WD occasionally, like once per month to keep parts lubricated. The place I used to take my JKU is a gravel pit area that was just sealed shut - no trespassing. So, just how bad is using 4HI while on dry pavement, not making any severe turns. The Tundra I just bought says in the manual to drive 10 miles per month in 4HI. It makes no mention of whether that should be on gravel or paved roads. Clearly I'll have a hard time in coastal N.J. finding a place where I can routinely drive 10 miles per month in 4HI. In my JKU or Tundra.
If your Tundra's 4wd system is part time and without locking hubs like the JK...
I don't see the need to drive in 4wd to keep things lubricated. When in 2wd, everything is spinning just like it would in 4wd.
Don't put it into 4wd on dry pavement. There's a possibility the driveline will torque up and be difficult to get it back into 2wd.
if you must engage 4wd once in a while, go to a back road and drive slowly for a bit with the right side wheels on the dirt shoulder.
My 2012 has been fantastic about going into and out of 4WD. Most of my recent use was to get more traction when pulling out some bushes. I always knew not to drive around in 4WD on dry pavements. Today I popped the owners manual CD into the computer. Sure enough, there is one sentence that states the 4HI should not be used on dry pavement. Now I'll have to bounce over to the Tundra forums and see what folks are saying about the mandate to drive 10 miles per month in 4HI.
About once a month I go the back way home, which is gravel, I run it in 4hi the whole time on gravel, every couple of months I stop on the way and go all the way into 4LO and run it up through the gears.
If you never engage 4WD on a part time system, eventually you will loose the ability to engage 4WD (I've seen it several times with friends and relatives vehicles that have never used their 4WD). It's not so much the using it as it is the engaging it. You're not going to hurt it if you put it in 4WD in you drive way of parking lot and roll back and forth a few times. If it did, any of us who ever go rock crawling would blow our transfer case every time. Just don't go driving around a bunch on pavement in 4WD, and be gentle with it, and all should be well.
Originally Posted by resharp001
I don't think I've ever heard this before. What is the reason behind it? I guess I don't understand why it would become more difficult to engage over time if it's not used. It's not like things are not being lubed and are seizing up
Former Vendor
Hope this helps!
-Kyle @rebeloffroad
