economy lift thoughts
thanks in advance -
picked up a new used toy - 07 with space 2.5" lift - wondering about 2 things - adjusting pinion angle with offset bolts and should I replace coil springs and remove spacers - this is running 33" and will not be a serious crawler but more expedi-type |
Are you saying that it currently has cam bolts installed? If that is the case, I would pull them out, find some cam bolt deletes to address the larger holes in the axle's bracket, and either go with control arm geo brackets, or add front adjustable arms to correct caster properly. If you plan to offroad that, first order of business is ditching cam bolts.
In regards to the spacers, there is nothing wrong with them for the time being. Longer term you're probably gonna want to pull em and replace with new springs instead, but there is nothing wrong with using spacers for now. I'd start upgrading steering components and such first. |
cam bolts on rear only - i will check angles this weekend - but the pinon angle was adjusted and does not hum or vibrate- all factory mounts on axle housing appear to be unmodified - nothing on front - I fixed death wobble on front with new parts tie rods, sway links, and new steering stabilizer shock - etc..
spacers i think will stay then - i do not notice a difference in ride from my TJ -
{control arm geo brackets...}
product suggestion are welcome - |
Originally Posted by mine
(Post 4309073)
(Post 4309074)
