Engine block heaters
Old Jun 22, 2011 | 01:14 PM
robbie.mckinney's Avatar
Default Engine block heaters
I'm going to Wyoming and with it being so cold I'm thinking an engine block heater would be nice does anyone else use one
Old Jun 22, 2011 | 01:27 PM
BLK08JK's Avatar
I've got one new in a box that I was going to install and never did... I'll sell it to you. PM if interested.
https://www.jk-forum.com/forums/show...28brand-new%29
Old Jun 22, 2011 | 02:06 PM
ronjenx's Avatar
While a block heater on a timer can be a good idea, I never found them really necessary.
My JK and VW diesel both start just fine at -30°F. I do use one on the diesel, but it's not needed for satisfactory service.
Old Jun 22, 2011 | 06:57 PM
AK4Dave's Avatar
It's not a matter of them starting or not....of course it helps, but it's a WHOLE lot easier on the engine to start when it's a little warmer, and you get that oil moving around everything just that much faster. Not to mention a warm engine puts out far less emissions than a cold one. Freeze block heaters are nice but you'll probably have to have a shop install it for you. There are a couple other options. A small, low wattage heating pad that you silicone to the bottom of the oil pan to warm the oil is nice to have. And/or you can get a heating element for the lower radiator hose that will heat the coolant up until the thermostat opens and then circulate throughout the system. These are real easy for you to do yourself. I have a block heater, but the jk came with it new, or I would have installed the lower radiator hose element. I've used them before and they work great. Oh and btw....I never plug in until it's at least 0 or colder. And even then it's on a timer so it comes on only for a couple hours in the morning before I leave.
Old Jun 23, 2011 | 10:07 AM
i went ahead and got one from the jeep dealership thinking ited just be nice in case i really do need one up there and with all the stress on my battery from amps lights and a winch ited be easier for the battery and the car to be warm when it comes to start in the colder temps
Old Jun 23, 2011 | 10:41 AM
The_Yeti's Avatar
if you dont mind me asking about how much did it run from the dealer?
Old Jun 23, 2011 | 11:27 AM
only 160 and thats with installation
Old Jun 23, 2011 | 04:57 PM
cbcwrangler's Avatar
This is what you really want. These are a factory option on several brands in parts of Europe, especially Scandinavia. They don't come cheap though - I think around $1200, but if you live in a very cold place, they cannot be beat:
http://www.parkingheater.com/product...ng-heater.html
Old Jun 23, 2011 | 05:17 PM
Kalamari's Avatar
I use my stock one all winter every winter. Gets down to -40 C for about a week every winter. Probably averages around -30 C for 2 months.
Old Jun 23, 2011 | 06:04 PM
AK4Dave's Avatar
At around $1200, I'll have to say no thanks. You can tap into the same wire as the block heater, or run a separate wire into the cab. Then just buy a small 110 heater, set it on low, and put it on the floor of the passenger side. It'll be on a timer the same way the block heater is. Works great...!!!
