Engine Control Module Update
Old Dec 6, 2007 | 06:11 AM
Gonzo's Avatar
Default Engine Control Module Update
DC replaced the engine control module on my JK over a month ago. This was to fix the issues I was having with the truck jumping into neutral when accelerating and the computerized throttle control warning light coming on at will. I have taken two long trips and probably have around 2000 miles on the new module. So far everything is fine with none of these issues coming back. It took 6 months for the service dept. to figure this out and that is only because it finally got bad enough to store codes. For those having these same intermittent issues this may be the fix however I still think it needs a little more mileage/time to be sure. The old module appeared to be running hot and it did not start acting up until we had the truck about 3 weeks.
