esp
Old Apr 22, 2008 | 11:54 AM
TheonlyREDhead 2008 JK's Avatar
Default esp
Can someone explain the esp for me when I should turn it off and such, or do you just shut it off when 4 wheeling?
Red
Old Apr 22, 2008 | 12:07 PM
MJS_Jeep_888's Avatar
The ESP is set up to help you keep all 4 tires planted on the pavement, and to keep your JK from pitching sideways into a rollover, such as from extreme lateral forces when taking a turn too tightly.
Off-pavement, it can severely reduce your wheelspin and sideways movements, which can effectively get you stuck by killing your momentum, and/or not allowing you to spin the tires to dig yourself out of mud, loose soil, etc.
I turn off ESP when I'm off pavement, because it really doesn't help much, and actually can hurt you (as aforementioned). In the wintertime, when there's a lot of fresh snow around and I want to play, I'll shift into 4HI and disable ESP completely, then do 4WD donuts.
(To completely disable ESP in 4HI, hold down the ESP OFF button for 5-7 seconds, until you hear a chime and see "ESP OFF" displayed in place of your odometer. ESP is automatically disabled in 4LO. Note that you can't completely disable ESP in 2WD mode, without modifying your Jeep.)
Old Apr 22, 2008 | 12:50 PM
Thanks Bro!
Old Apr 22, 2008 | 12:52 PM
You're very welcome.
Old Apr 22, 2008 | 06:30 PM
Rockrunner8's Avatar
Default ESP for lifted jeeps
I've got an 07 4-door Rubicon. 3" Teraflex lift and 35" Hankooks. I'm hearing you can't just turn off the ESP on modified Wranglers without going to the dealership. And even the dealerships don't always get it right. And if you take it in, does the dealer give you a hard time about the warantee?
Thanks guys. This site is great.
Old Apr 22, 2008 | 06:42 PM
From what I've heard, the TSB to enable "full off" ESP in 2WD mode isn't working all the time... but that's 3rd-hand information. As far as the dealership getting it right, the sad truth is that most Jeep dealers are pretty incompetent when it comes to JKs.
To answer your question about warranty, it's totally subjective and you may get 10 different answers from 10 different dealers. If something breaks and your dealer is a jerk, they'll tell you that because you modified your Jeep, the damage isn't covered under warranty. Then again, if you find an off-road friendly dealership, they may be willing to help you out.
Welcome to the site, and happy Jeeping!
Old Apr 22, 2008 | 07:27 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
There is a fuse that you can pull to kill the esp, thats what I do when I go wheeling, not sure you would want to drive on street with it pulled as it also disables the antilock brakes
Old Apr 23, 2008 | 02:41 AM
flip2spin23's Avatar
what fuse is it
Old Apr 23, 2008 | 11:45 AM
mkjeep's Avatar
Fuse J- 07 on the 07's Might just be j-7 can't remember I did the toggle switch mod. Had a couple beers, can't remember , it's the dang fuse with a j and a 7
Old Apr 23, 2008 | 12:09 PM
sw0cb's Avatar
The ESP can be completly turned off on all 08 JKs, you get a little yellow sheet of paper in your manual telling you how to do it. It can be trickey tho, it took me forever to get it to work but now my esp is completly off all the time. 07s can be reflashed by the dealer to make the code work on them too.
