ESP BAS light on??
Old Nov 5, 2010 | 07:22 PM
07XMan2Door's Avatar
Default ESP BAS light on??
I just installed my Terraflex front brake lines. I bled them out & then my dash lit up with an "ESP BAS" code.
Manual says to take to stealership. I'm assuming that the bleeding process triped this code. Can Autozone reset this or do I have to take it in to the Dealer?
Any help appreciated!
Old Nov 5, 2010 | 08:01 PM
Yamaha90's Avatar
one of the sensors might be screwing up and giving you some issues. When i had those lights come on it was a bad wheel speed sensor and the dealer replaced it no problem. Not exactly sure if having this code wiped off would be a good thing or not because it could lead to your ESP and or brakes not working properly in the event of an emergency. Good luck on your find.
Old Nov 5, 2010 | 08:12 PM
Thanks. I guess I'll run it in & let them check it out.
Old Nov 8, 2010 | 01:14 PM
TedC's Avatar
can you update us on what they told you? i have an unmodded 2010 JK and i got the ESP/BAS and fishtail indicators today for the first time. i am wondering if they are going to turn me down any diagnosis for failure to replicate the problem at the dealership. i did photograph the display but no idea if they will go by that.
Old Nov 9, 2010 | 03:45 PM
I'll post what I find out here. I will prolly go into town tomorrow & talk with service. I'm sure it happened when I installed my new brake lines. While bleeding the brakes the pedal hit the floor a few times.
Old Nov 11, 2010 | 06:08 PM
I took it in today. I thought they would just get me in & hook it up, reflash it or whatever. He wanted to keep it. Not today.
He told me to unhook my battery for over a half hour. It's sitting in the garage unhooked. I'll check it when I get home from work tomorrow. Hope it resets itself.
Old Nov 13, 2010 | 07:05 PM
ride2099's Avatar
MY esp bas light have been light today just riding normaly on road and I seen that signal ??!? what that mean I do nothing on brake on that stuff the only thing I see I put my front and rear bumper winch and 37 spare tire on about 2 day ...does the weight of my parts have something to do with this ?!?!? cause its the firts time see that normal I run 4" lift with 37 and yesterday I put all my bumper on so I guees weight is the reason just le me know If its dangerous for something to run like this
Old Nov 14, 2010 | 07:15 PM
I'm not sure why your light came on. I really don;t know if the Jeep has a brake actuator or not. I know my toyota pichup had one & after installing the lift the brakes didn't work until I extended the actuator downward.
Mabey someone with some first hand experience will help you.
Old Nov 16, 2010 | 09:05 AM
ride2099's Avatar
my light turn off about 2 day I start my engine and the light light on with the traction control light and turn off the engine after that i turn key to on and off three time and after that I restart the engine and boom 5 seconde later no more light I guess my computer laging
Old Nov 16, 2010 | 01:03 PM
nofr13's Avatar
i had a steering wheel position sensor fail which gave the same indication failure. took 5 days to get and 2 hours to install. all coverd by warranty
