Fire risk prompts recall of nearly 87,000 **2010** Jeeps
FYI - not sure if everyone with a 2010 auto and a manufactured date of 7/14/10 or earlier has read/seen this, but thought I'd share.... Of course, I'm one of them - so, I'll be waiting for my recall...
DETROIT (AP) — Chrysler is recalling nearly 87,000 Jeep Wranglers in the U.S., Canada and elsewhere due to a risk of fires.
The recall affects only Wranglers from the 2010 model year that have automatic transmissions and were built before July 14, 2010, the National Highway Traffic Safety Administration said in documents posted Saturday on its website.
Debris can get caught between a plate that protects the transmission and the catalytic converter, causing a fire. A catalytic converter is part of the exhaust system and uses heat and precious metals to control pollution.
Chrysler knows of at least 14 complaints of fires caused by the problem with 2010 Wranglers. The company says it doesn't know of any injuries. It said debris can get trapped when the SUVs are driven off-road or through tall brush.
Chrysler, which makes the classic Wrangler and other Jeeps, will fix the problem free of charge by replacing the plate with a bar so debris doesn't get caught.
The recall affects about 68,000 Wranglers in the U.S., 6,000 in Canada, 1,500 in Mexico and about 11,000 in other countries, Chrysler spokesman Eric Mayne said. Chrysler will contact all the owners by mail. Recall work is expected to begin this month.
The National Highway Traffic Safety Administration also checked Wranglers from the 2007 through 2012 model years and determined that only the 2010 models had the debris problem. Mayne said the 2010 Wranglers had a transmission plate and catalytic converter that were configured differently than the Wranglers from the other model years.
NHTSA said in documents that it had received 14 complaints of Wrangler fires from the other model years, but Mayne said there was no pattern or common cause in those fires.
If you have questions in the meantime, you're encouraged to contact Chrysler at 800-853-1403 and ask about recall M22. Or, if you prefer, you can ring NHTSA at 888-327-4236 and inquire about campaign #12V216000.
