Flat Fender Flares
In my opinion, and it is totally subjective, it will not look so well. The 33" is only an inch larger than factory tires, so a half inch from wheel hub. With a 2" lift/level, and then opening up about 3 more inches with flares, it's going to a have a very large gap with a half inch bigger tire in the wheel well and an additional 5" of wheel well opening.
Again, my opinion is meaningless while talking about your property, but you asked. And no Jeeper is going to shun you, all Jeeps and Jeeperes are unique.... unless they are stock.
You'll be jonesing for 35" tires pretty quick I bet!
I'm sure it will be fine, but the biggest determining factor isn't what I or anyone likes near as much as what you like to see.
I would do either the lift or the flats. Flats will give you the room you need for the 33's and will give you the look of around 4". No real reason to run a lift with flats. I would agree with Larry that you will find you want 35's pretty quick.
I have never felt the urge to just buy Jeep parts because I felt like it.......Got to go, just got a message from FedEx "Package Out For Delivery"
