Which floor jack?
Old Nov 11, 2011 | 11:30 AM
OOphead's Avatar
Default Which floor jack?
So my little 2 ton AutoZone special doesn't event come close to lifting my 2012 JKU Sahara. Need to get a new one and have been looking at Harbor Freight as of now. Questions that arrise:
1. Do I go for 2, 2.5, or 3 ton?
2. Height: On average most lift about 18-19 inches. There are a couple that go 20-24.
3. I only use Harbor Freight for hand tools that I usually end up breaking and other misc goodies (latex gloves, wood clamps, bungees cords/straps, tarps, etc) I will most likely be getting the jeep on stands, but should I trash the idea of putting a 2.5 ton vehicle on a Harbor Freight floor jack and getting under it?
The most I plan on doing is tire rotations, oil changes, eventual suspension mods (my buddy owns a garage but usually way to busy to get me in when I buy something new)
Old Nov 11, 2011 | 11:50 AM
shoe1724's Avatar
Interested in knowing the answer to this too. My floor jack doesn't get high enough to do a tire rotation. It is very old tho.
Old Nov 11, 2011 | 02:21 PM
nthinuf's Avatar
You do have jack stands, correct? If not, that is where you should spend the money. Get the biggest, beefiest, tallest stands you can afford, and just use a block of wood on the floor jack to lift it high enough to get a stand in.
Old Dec 1, 2011 | 08:32 AM
OOphead's Avatar
Ended up getting a craftsman 3 ton floor jack that lift 19 3/4" high.
Does the job nicely whether I lift by frame or by axle.
Old Dec 1, 2011 | 08:35 AM
littlecricket's Avatar
as far as floor jack I can't help but I have the 6 ton jack stands from harbor freight and I've never had a problem with them.... infact I'm not even sure they've gotten scratched and I've used the hell out of them.
