Front end shake when wheel is close to lock...
When turning at low speed, in 4wheel or not, the front end "jumps" on my currently stock 07 Unlimited Rubicon. Only occurs when close to lock like when going into parking spaces, maybe it just wants to keep running?!
The 4WD is NOT a "full-time" 4WD design. IOW, 4WD should only be engaged on snowy/icy pavement or when off-roading. Otherwise you'll get wheel hop exactly as you are getting now...
If it's happening in 2WD, you've got an issue...
It may be simple
Have you considered that it might be simply the tires? When you turn sharply, the tires 'lay over' and ride more on the shoulders. On your Rubicon, that would mean that they are turning on some pretty substantial knobs on the tires. That could definitely cause the feeling that you describe.
Just a thought
Just a thought
