Gas Mileage
Old 08-25-2011, 12:33 PM
Brandon1024's Avatar
Default Gas Mileage
So I purchased a 2007 JKU with 40000 about 3 weeks ago. On the way home (completely stock might i add) I got 21.6MPG Highway. Since then Ive gotten a 2.5 inch teraflex coil lift but that is my only real exterior mod (that would make a difference) ... Everything else is interior. Well on my way to college on the highway I was getting 17mpg which I'm fine with however now that I'm in town and driving around I'm getting 9-10 mpg... Thats just ridiculous I could maybe see if I was running like 35 or 37's or something but just with the Moab take off 255/70/17 i believe it is I think I should be getting way better. Am I just crazy? I got better in my jeep commander with lift and 32's... Btw I have an automatic with 4.10 gears.
Old 08-25-2011, 12:38 PM
jkfanatic's Avatar
9-10 seems low to me. i think i get about 14 in town with 33's and 3.73's
Old 08-25-2011, 12:42 PM
my point exactly... i think i should definitely be getting at least 14... i read that people get 13-14 all the time with 35's... I wouldn't even expect this mileage when i get my 35's and super chip...
Old 08-25-2011, 03:54 PM
dinner time bump
Old 08-25-2011, 03:55 PM
centerfieldr162's Avatar
I have 35s and a 3.5" lift and I get about 12 mpg.
I assume you've reset your MPG thing on the speedometer to make sure it is really reading 9-10 ?
Old 08-25-2011, 04:00 PM
JKred's Avatar
3.21s and 35s and I net about 18mpg... Check your ebrake make sure it's not hung up... And check your brakes as well, you said you bought it used with 40k? Could have a caliper hung up causing is to drag... And pull right or left if you take your hand off the wheel?
Edit: if all your doing is driving around town you might my notice a hung brake as much as on the highway.
Old 08-25-2011, 04:03 PM
Sandfreek's Avatar
How does electronic stuff that runs off of a battery reduce mpgs?
Sent from my ADR6350 using Tapatalk
Old 08-25-2011, 04:04 PM
Heavy as fck!
Old 08-25-2011, 04:07 PM
Yes of course I have reset it probably 3-4 times now because I'm in disbelief.
I'll have to look into this all more... I know its not the Ebrake but idk about calibers although it doesn't pull either way and is all aligned.
Originally Posted by ludski
go hard reset it beeber. unplug battery.
dont forget sub amp will drop you down 1 or so.
i gained 1.5 after taking all sound shit out.
Boober from 19 to 9 is more than 1... now if u add a 0 on to it then we will be in the right spot.
Old 08-25-2011, 06:38 PM
jeeeep's Avatar
when you installed the lift, did you remove the front air dam and leave it off? That will affect mileage. Are the tires still stock or did you change - you mentioned Moab take-offs.
are you using 87 octane? I know, dumb question but when I traveled recently, I noticed some of the gas stations regular was actually 85 or 86.
Quick Reply: Gas Mileage
