Hard Top front panels?
Hey -
Just took the panels off the Jeep for the first time tonight, and went to put them back on. I read the manual and think I put them back on in the right order, however when I really look at it, it seems as though its lifting up a smidge in the back where the two panels meet. Is this normal? I can't see how I can possibly make it any more flush than it is.....I just don't want it to start raining in my Jeep.
Any advice would be greatly appreciated.
Kelly
Kelly
They should fit pretty flush. Passenger side goes on first. Make sure the little stud that is on the side towards the front fits down into the roll bar. When I put mine on, I usally lift up the middle a few times to make sure the seal is good. Then move to the drivers side and do the same thing.
If you're not fititng flush, make sure that you didn't lower one of the back feet. In the middle of each pannel on the back is a little black foot that flips down. That is to be used when you have the rear top off so you can use the front pannels as a type of bikini top. You might have lowered one by mistake that that could keep it from fitting flush.
Good luck.
Good luck.
Thank you so much! I'll check it today. I really do appreciate it. We've got rain in the forecast for this weekend, and I had visions of rain pouring in through the top.
Thanks again!
Kelly
Thanks again!
Kelly
