Heeeeellllllpppppp
Old Jul 23, 2008 | 06:14 PM
kshox's Avatar
Default Heeeeellllllpppppp
I think that my jeep has epilepsey... I just drove home from across town and it was running fine. Packed up for my trip tomorrow and nothing will turn on. No Hazzards, no interior... nadda. However every once and awhile the hazzards sparkle and "nofuse" comes up on the ditigal spot with the readings... any suggestions?
I've already unhooked the battery and checked for a loose fuse...
Old Jul 23, 2008 | 06:21 PM
kshox's Avatar
P.S. It also won't turn over
Old Jul 23, 2008 | 07:00 PM
x No Compromise Offroad x's Avatar
Did you connect the battery back up....sorry just kidding....
...only things that come to mind is if the alternator is not charging the battery.....have you tried to jump it off?.....or do you have a meter to check for voltage?.....
Old Jul 23, 2008 | 07:08 PM
Desert Fox's Avatar
Veteran: Navy
Smile
It would be easier to answer if we knew what year and model JK you have and which mods you have added. Your location might also provide some clues.
Old Jul 23, 2008 | 07:16 PM
deconstructionist's Avatar
Gettin ANYTHING? a click? a buzz?
DONT overlook the obvious....is it in PARK (auto) or in neutral (stick)??????
Could alwats try to pull................. IIRC Fuse M13...let it sit for a few minutes and then plug it back in an re-try.
Old Jul 23, 2008 | 07:24 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
see if it will still display dtc codes
http://project-jk.com/jeep-jk-write-...what-they-mean
Old Jul 24, 2008 | 07:15 AM
noot's Avatar
You've checked for a loose fuse... how about a blown fuse?
Old Jul 24, 2008 | 07:20 AM
PONCH's Avatar
Check your lights, like a dome. No love there check the connectors. Connectors check good run your battery to your local auto zone.
Or..Connect jumper cables and see if your lights come on. If so, start her up. Remove jumper cables if you jeep dies, it's your alternator.
Old Jul 24, 2008 | 08:01 AM
only_in_my_jeep's Avatar
Did anything (specifically dash) get wet? Not sure if it did or that that's the problem just one more thing on a list of other good things to check out.
Old Jul 24, 2008 | 08:03 AM
greenmachine07's Avatar
i thought jeeps were water proof
