Help with gear ratios.
Old Feb 23, 2012 | 09:34 AM
duke2julius's Avatar
Default Help with gear ratios.
Whats the best gear ratio to go with on a 08 jk Unlimited X on 33s. Im eventually gonna throw on 35s. Is there a good ratio for the both? Or should i go with different ratios for each size?
Old Feb 23, 2012 | 09:45 AM
j33p4life's Avatar
going different ratios would cost a lot more to have them switched then just switch to 35's now. go with 5.13 if you will be rock crawling. go with 4.88's if not. both will be fine with 33's
Old Feb 23, 2012 | 09:53 AM
Cool thanks man!
Old Feb 23, 2012 | 10:11 AM
j33p4life's Avatar
yep!.......
Old Feb 23, 2012 | 11:00 AM
mhaines's Avatar
Might take a look at the chart as well
