help if ya can
Old Oct 6, 2011 | 07:31 PM
dj422gpd's Avatar
Default help if ya can
just installed Rugged Ridge front light gurads on head lights, counted the number of turns i turned each screw to get them out, put them back in the same way and now the head lights are alll screwed up, I cheked the head light adjustment thread but never touched the adjuster when i installed them.. ANY SUGGESTIONS?????????? thought i was very careful doing this but oops i screwed it up some where, has anyone had this problem????? all smart ass comment are welcome, im a good sport
Old Oct 6, 2011 | 07:33 PM
dgnr8's Avatar
When you say scewed up, what exactly do you mean? Are they ppointing some wierd way or not tight and rotating?
Old Oct 6, 2011 | 07:36 PM
dj422gpd's Avatar
looks like the lights are cris crossed when you drive it
Old Oct 6, 2011 | 09:19 PM
Runewolf1973's Avatar
Same thing happened when I installed my RR light guards. Found out that I had accidentaly turned one of the lights unknowingly and installed it so the lens was tilted to the side. I had to take the guard out, unscrew the light, and reposition the lens, but yeah, you will probably still have to check the adjustment with the torx screwdriver. No biggie.
Old Oct 6, 2011 | 11:58 PM
Hammer002's Avatar
the lenses are "keyed". there is a plastic notch they fit in at the top. my guards went on fine, but hit this snag when i went to the ipf lenses. make sure the notches are lined up and the lense is flat in the housing, then carefully screw it back together while holding the lense in place
Old Oct 7, 2011 | 05:19 AM
dj422gpd's Avatar
Thanks everone, I took it all apart and re installed everything and i think i did the same thing and did not have them seated correctly so hope it corrected it.
