HOW do you...
Old Mar 25, 2011 | 05:27 AM
JacKed 8's Avatar
Default HOW do you...
get the torx bolts loose on the hood hinges? I want to install my Hi-Lift across my hood, and I've got the mounts...I just can't get the bolts loose? has anyone else had this problem???
Thanks, Sam
Old Mar 25, 2011 | 05:35 AM
JK.nick's Avatar
Manpower!
You've really got to work at them. Just make sure to not strip them, or else you're F****d!
Old Mar 25, 2011 | 05:56 AM
JacKed 8's Avatar
i've got the right size torx wrench, and I've been pulling at this thing for a while...does it need a drill? This seems worse than the taking off the 4x4 shift knob...I'm not even budging these bolts....anyone have any tricks??
Old Mar 25, 2011 | 06:44 AM
mpkelley20's Avatar
Do you have a breaker bar? Maybe you need the extra length for leverage?
Old Mar 25, 2011 | 06:47 AM
dgnr8's Avatar
NO DONT DRILL!!!!
Mine were a pain before i used a bigger/longer socket wrench. That "broke" them from being stuck and they came right out.
Old Mar 25, 2011 | 08:14 AM
Torrin's Avatar
Thanks, Sam
I use a longer socket driver and if that fails, I tap the handle of the socket with a rubber mallet (tap hard)
Old Mar 25, 2011 | 08:43 AM
TN_JK_GA's Avatar
Default Painted
Are yours painted?
Try using a knife to trim around the bolt.
Also heat works. Use a heat gun or hair dryer.
That is what I did with my TJ and my HighLift rack.
Old Mar 25, 2011 | 08:45 AM
JacKed 8's Avatar
thanks for the advice guys -- obviously my little torx wrench is not doing the trick...yes they're painted (I had the same thought), so I will probably try the hair dryer tonight and go at it again. What a pain for something that should be such an easy install.
Old Mar 25, 2011 | 09:44 AM
dgnr8's Avatar
Man i've found the smallest easiest things are usually a pain in the ass!!!
Good luck bro
Old Mar 25, 2011 | 05:55 PM
JacKed 8's Avatar
Well gave it another try tonight....after hammering the paint around the edges of the bolt and hammering the torx bit into the bolt a little bit i gave it as much strength as i had and they finaalllyy budged. Looks great on the hood instead of my garage floor!
