How to get WAY BETTER MPGs
Old Jul 14, 2008 | 08:12 AM
noot's Avatar
I've also been recently driving 100km/h, rather than 110+.
Based on my brief testing technique (Flat ground using cruise, and resetting the dash L/100km comp) that 10% increase in speed results in close to 20% worse mileage. I guess that's what happens when you drive something as aerodynamic as a brick
-13.2 L/100km + at 110+km/h ish, to
-less than 11 L/100km at <100km/h.
Totally worth it to me. Takes a while to get used to it, and to deal with "glares" from speeders, but it truly is a lot less stressful and anger inducing
Old Jul 14, 2008 | 08:38 AM
RevyJKU08's Avatar
I love those speeder stares or flipping of the bird.......... as they pass me and the family with the top off, doors off cruising in the sunshine & enjoying the mountian scenery! They don't know what they are missing going a little slower.
Old Jul 14, 2008 | 08:45 AM
SCJK08's Avatar
yea, Ive started calling them proctologists since they're up ur ass...heard it from a guy on tv
Old Jul 14, 2008 | 09:15 AM
mikejwil's Avatar
Originally Posted by wranglerV8
I can definately relate with the 12.2.I know my speedo is off and I'm only using it to calculate,but I have never seen anything above 16.When I drive on the interstate,I turn the o/d off and cruise at @ 75 mph(per GPS) and 3000 rpms.
Why are you turning the o/d off? Turn it on while cruising (that's what it's for) and you will see better MPG. I turn 2500 RPM @ 75 MPH in 6th. IIRC the top gear in the auto is even taller.
Old Jul 14, 2008 | 12:39 PM
TeraFlex's Avatar
Sponsoring Manufacturer
16.47 on my last fill up.
Old Jul 14, 2008 | 12:45 PM
boots's Avatar
Drive down hill alot.
Old Jul 14, 2008 | 12:46 PM
MJS_Jeep_888's Avatar
He's driving with OD off because he's lifted, with larger-than-stock tires, but no regear... stock gearing is set up for stock tire size - when you go to bigger tires but don't also change your gearing, your power/performance is pretty severely impacted (and much more so with an Auto transmission).
Old Jul 14, 2008 | 12:51 PM
gold knight's Avatar
That's great, the trip back is just gonna suck
Old Jul 14, 2008 | 03:51 PM
08{GA}RUBICON's Avatar
Originally Posted by pearl-drum-man
No doubt, the way/speed you drive will have a much bigger impact on economy than any gizmos you can bolt on or dump in your tank
Really?
Old Jul 14, 2008 | 04:40 PM
berg's Avatar
Originally Posted by camden19
On a resent road trip from Houston to Austin Texas I drove the speed limit ,70 w/cruise set and the over-drive turned off and got a disappointing 12.2 mpg from calculations not the JKs computer.
Why would you cruise with the OD Off? Right there you are dropping your MPG big time.
Want to save gas? Keep the RPMs low. On the roads I try to keep my RPMs below 2500 at all times and generally putter around at about 2000 or less.
South Jersey is mostly flat so it's easy to do.
My last calculated MPG was 19.5 city.
