How to turn off hill assist!!
Old 08-23-2011, 10:35 AM
Dkjk's Avatar
Default How to turn off hill assist!!
I'm sure there has already been a post on this topic but I figured it bares repeating!
If you're like me, and you know how to drive a manual transmission, the hill assist feature on our JK's could be more bothersome than helpful. Well I have the remedy for the disease of the HSA feature!
[vehicle has to be on a level surface to perform deactivation of the HSA]
1. Start with the engine off and vehicle in PARK (automatic
transmission) or NEUTRAL with clutch out
(manual transmission) with wheels straight. Apply parking
brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the
clutch out, rotate the steering wheel 180° counterclockwise
from center.
4. Press the ESC OFF switch four times within twenty
seconds.
5. Rotate the steering wheel 360° clockwise (180° clockwise
from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESC
Activation/Malfunction Indicator Light” will blink several
times to confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off
HSA. Repeat steps 1-7 to re-enable HSA functionality. I love it!!
Post a if this satisfied your urning to disable the HSA
Old 08-23-2011, 10:41 AM
drschem's Avatar
Then do the Hokey-Pokey and turn your self around...
Old 08-23-2011, 10:56 AM
Dkjk's Avatar
Old 08-23-2011, 11:51 AM
fishnerd206's Avatar
In the 2011 you can turn it off via the menu function on the steering wheel.
Old 08-23-2011, 11:56 AM
mgoony's Avatar
I didnt know this... :(
Thanks
Old 08-23-2011, 12:20 PM
Dkjk's Avatar
I ain't got all that fancy stuff...
Old 08-23-2011, 12:31 PM
Tnsatbhs's Avatar
Awesome! Thanks, at first i thought hsa would be nice to have but its actually more of a hindrance than a help.
Old 08-23-2011, 12:46 PM
jjntj2003's Avatar
i'm to lazy to read how cause it seems to be a p.i.t.a. with a 6spd.
check that i just went to get my manual and theres not one just a dvd and user guide. damn it!!!!
Old 08-23-2011, 08:15 PM
Navyvetnorwich91's Avatar
thanks very much for the tip!
Old 08-23-2011, 09:29 PM
It is fairly easy, just hit menu and scroll till you get to "personal" from there just scroll till you see "Hill Assist" then hit the right arrow and it will say "off"
I found it by accident.
Cheers!
Quick Reply: How to turn off hill assist!!
