Important warning!
Forum Friends,
Please take a minute to read this as it may save you from very costly damage or worse.
As some of you know, few weeks ago we ran Fordyce Trail in the Lake Tahoe area. Our good friend HONEY BADGER suffered a vehicle fire due to his winch power cables being pinched and overheated softening the insulation. At the pinch the insulation wore through and arced and caught fire.
Today I was tinkering with our Jeep and decided to make sure our winch power cables were free from restriction. When I started wiggling them I found the hot wire pinched and while I was wiggling it acred and smoked!!!
Obviously I couldn't get it unhooked from the battery fast enough! We were WAY too close to suffering this same fate.
PLEASE take a few minutes to check your cables to make sure you do not have this problem. I will be getting new cables along with extra heavy duty insulation.
Rather be safe than sorry.
Obviously I couldn't get it unhooked from the battery fast enough! We were WAY too close to suffering this same fate.PLEASE take a few minutes to check your cables to make sure you do not have this problem. I will be getting new cables along with extra heavy duty insulation.
Forum Friends,
Same thing happend to me last year. I had my solenoid box mounted above over the middle of the spool and the winch cable rubbed against the positive lead and caused a fire.
The wires got so hot that it melted my battery terminals to the ground and everything in its path. I was lucky I noticed it and cut the super hot lead with my knife and grabed a fire extinguisher from a friend to take care of the fire. If you mount the solenoid box over the middle make sure your cables have plenty of room between the winch spool and grill and always carry a fire extinguisher.
