It's going to be a colllld winter
Old Oct 15, 2007 | 09:06 PM
wayland1985's Avatar
Default It's going to be a colllld winter
Driving to school this morning at 6, it was about 40 out. All was warm n' cozy, excecpt for one heck of a draft coming from the foot well, near the driver's door. Any thoughts???
Old Oct 15, 2007 | 10:08 PM
yetibear's Avatar
Sorels
Old Oct 15, 2007 | 11:45 PM
Devilish's Avatar
any of the plugs in the firewall come out??
your air con vent down there could be leaking air straight from outside??
Old Oct 16, 2007 | 10:43 AM
seer1's Avatar
There is a big plug/grommet over there. If you look up under the dash, you should be able to see it.
Sorrels aren't a bad idea, but I saw a thread where some fellow suggested setting fire to another JKers front seat to get rid of an oil stain...that could work for a bit.
Old Oct 16, 2007 | 01:18 PM
MJS_Jeep_888's Avatar
You're a liar. It was me that made the suggestion, and I didn't suggest that the guy set fire to his front seat.
Last winter, I also had a draft in that location. Know how I solved it? By burning the Jeep to the ground! NO, not really (take THAT, seer1! ).
Actually, I've had my doors off several times before it got cold, and haven't had that draft since the first time the doors were reinstalled. Try rehanging your driver's side door - it may not be seating properly against the sill, which might explain the draft. Hope that helps!
Old Oct 16, 2007 | 04:20 PM
I'll have to try that tomorrow... Might as well put on the nuts too, for the winter... Thanks
Old Oct 16, 2007 | 04:24 PM
zero2krazy's Avatar
Remote starter. I highly recommend it. Got mine from the dealer for $360 including install. I love it. Wouldn't give it up for anything.
Old Oct 16, 2007 | 05:23 PM
I have a manual transmission... Plus, the heater seems to heat up quick enough, so I'm sure i can run outside and turn it on before I eat a bowl of cereal or something...
Old Oct 16, 2007 | 09:35 PM
Dizzyliz's Avatar
Gortex coat ~good boots ~Hat & gloves.
Old Oct 16, 2007 | 09:45 PM
yetibear's Avatar
and some toasty wool socks!
