Jeep wont run!!! Help!!!
Old Jul 12, 2009 | 03:01 PM
LaxAHolic's Avatar
Default Jeep wont run!!! Help!!!
today my jeep quit running while we were messing around in a bit of mud..hit a deep rut in the puddle and the jeep cut out immediately...to my knowledge i didnt hit the air intake..praying it didnt. but it was not deeep enough for that. when u try to turn it on, it clicks..thats it. what do i do??!
Old Jul 12, 2009 | 03:05 PM
LaxAHolic's Avatar
urgent bump
Old Jul 12, 2009 | 03:12 PM
rob7765's Avatar
Clicking? Try power related issues? or Starter issues? Battery, cabling, starter, altenator(although would cause not start), fuses, etc.
Old Jul 12, 2009 | 03:18 PM
joes-jk's Avatar
check the air box. see if there is any mud or water in it. if there is its possible u got water in the engine.
idk too much about newer cars but on my old dodge i used to nock my nutral saftey switch got loose and that could cause it not to start. i think is on top of the tranny, not sure.
its weird it just cut out, but that happened to scott07's jeep in the water and it click he waited five and then it started.
try to arch the starter that way it will run and u can get it to a shop.
sorry im not much help, but im not used to newer cars and all of there computers .
Old Jul 12, 2009 | 05:33 PM
LaxAHolic's Avatar
dude, im replacing the plugs..hope that works.
idk what else to do
Old Jul 12, 2009 | 05:47 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
idk what else to do
yeah spark plugs arent going to help you, DID YOU OPEN THE AIR BOX AND CHECK FOR WATER??????? check the filter see if its wet.....if the started is just clicking you may have got mud in it how thick/deep was the mud...you could try hittng the starter with a hammer a few times then crank it again, thats if you didnt get water in it.
Old Jul 12, 2009 | 06:31 PM
LaxAHolic's Avatar
so what do i do then? i need guidance. im 18 and pretty useless with fixing this. but ive got to. what can i do?
Old Jul 12, 2009 | 06:34 PM
mkjeep's Avatar
Did you check the airbox, umpteeth time?
Old Jul 12, 2009 | 07:04 PM
LaxAHolic's Avatar
yea...little bit of water.
Old Jul 12, 2009 | 07:10 PM
LaxAHolic's Avatar
do u honestly think swapping out the plugs wont do anyting?
