JK brakes and rotors
Old Sep 23, 2013 | 02:43 PM
pasteris71's Avatar
Default JK brakes and rotors
I have a 2011 Jeep JK and recently brought it in for an oil change and tire rotation. The service guy came out and told me I need new rear brakes. Said my fronts were fine. He also said that the rear rotors could not be turned because they come smaller from the factory. I have never heard of that. He then proceeds to give me a price of almost $535 to replace both rear rotors and all pads. I almost flipped out!
Has anybody ever heard of that? The rear rotors being smaller/less thick then the front rotors. Or am I getting scammed from the dealer?
Old Sep 23, 2013 | 02:48 PM
mbanik's Avatar
The rears do wear out faster than the fronts.
$535 seems high ... rear pads, rotors and hardware can't be more than $150 total in parts (mid grade).
Thus $375-400 in labor ?
Old Sep 23, 2013 | 03:05 PM
Rob 12B1P's Avatar
You need to find a different mechanic. This ones trying to rape you.
Old Sep 23, 2013 | 03:17 PM
BillyJack's Avatar
My rear brakes wore out a lot faster than my front. I had them all replaced but didn't turn the rotors. Do you think you need yours turned? If not, I'd just replace the pads.
Old Sep 24, 2013 | 05:25 AM
Yankee's Avatar
If the rotors are in bad shape and cannot be turned then replace them yourself. You can do it cheaper and it is not very difficult. I believe there are writeups if needed.
If the rotors are in good shape, not burned or grooved, you can probably just replace the pads. I did on mine and they work fine.
Old Sep 24, 2013 | 05:37 AM
08REDROCKX's Avatar
My rears were burnt up in 25K and ruined the rotors. I tried to get the rotors turned but was turned away so I bought new rotors at O'Reilys for $38 a piece and did them myself. It was fairly easy, and I rarely work on my own vehicles but Jeeps are easy to work on. BTW fronts were fine but I changed them anyway to put on better quality pads. I have 60K now and just rotated tires ... front and back are still in good shape.
Old Sep 24, 2013 | 04:15 PM
familytime's Avatar
JK Forum Regional Rep
You can get all the parts you need for a lot less than that.Save even more by do it yourself
Old Sep 24, 2013 | 04:18 PM
TURTLECON's Avatar
Can someone clarify what you mean by "turned"?
Old Sep 24, 2013 | 04:19 PM
Bonedoc's Avatar
Check out ebay. I got a complete set of front and rear cross drilled and slotted rotors with ceramic pads for about $210.00 shipped. Definitely a good deal and they work great. Cheaper than going to the auto parts store as well.
Old Sep 24, 2013 | 04:30 PM
karls's Avatar
Essentially shave down the rotor to a smooth surface. The lathe turns the rotor as the bit moves across the surface.
Sent from my GT-P5113 using Tapatalk 4
