jk trouble
Old Jul 18, 2010 | 11:29 AM
LaxAHolic's Avatar
ill check that now, thanks.
Old Jul 18, 2010 | 12:24 PM
LaxAHolic's Avatar
okay, i got the jeep to heat up again today and didnt hear the fan turn on. i tried turning the airconditioning on to get the fan to try to cool the condensor. no luck. do u guys know how i can troubleshoot the fan? whats its electrical route? where can i find where the fan wires are run so i can check them? thanks in advance.
could it be something as simple as a bad fuse?
at highway speed should the jeep be able to make a 3 hour drive home to the garage without the fan if i cant fix it here?
Old Jul 18, 2010 | 01:07 PM
RockyBlue's Avatar
Not sure how to test the fan besides checking the fuse and connection to the wiring assembly. I guess if you had a mutlimeter you could see the voltage coming from the and of the connection to determine if the fan is toast or the relay to the fan.
A lot of factors go into that drive, heat of the day, how far you have to drive locally before you get on the highway, etc. Once you are going 55 mph you should be good to go though.
Old Jul 18, 2010 | 01:11 PM
RockyBlue's Avatar
http://www.ehow.com/how_4964990_check-radiator-fan.html
Old Jul 18, 2010 | 01:13 PM
LaxAHolic's Avatar
so check the fuse?
im going to try and drive it during the evening, so 80 degrees or less.
no alot of stop in go in augusta, i can ride the parkway almost home.
think ill be okay?
Old Jul 18, 2010 | 01:24 PM
RockyBlue's Avatar
I always check the easy stuff first. Fuses are pretty simple. You can probably swap it with another one.
Fans can be tough because if it is going bad the fan may kick on for a while then seize up.
Worse come to worse you just pull over and let the car cool down. Bring a jug of water to refill the reservoir. Might take you a while but you should make it.
Old Jul 19, 2010 | 03:15 AM
Mark Doiron's Avatar
If you're trying to drive without your cooling fan, here are a couple thoughts:
1. Run your heater. That probably sounds nuts in August, but it will lower coolant temp some.
2. Don't run your air conditioner--your engine doesn't need the additional load right now.
3. Carry a bottle of pre-mix Chrysler (and ONLY Chrysler) anti-freeze. If you boil over, use it instead of just plain water (using plain water will lower your boiling point, just making a repeat of the boil over happen that much more quickly).
4. No one has mentioned checking your thermostat. If you're certain it's the fan, then the thermostat is probably good. But, if the thermostat is stuck closed, it will stop your antifreeze from flowing, eventually causing a boil-over. This includes highway driving. You can pull the thermostat out and run your Jeep without it. Because the coolant doesn't stop flowing, your engine will run cooler, your heater won't get as hot, and you'll be polluting more. But, I've know folks who drove for years without a thermostat.
Old Jul 19, 2010 | 09:00 AM
LaxAHolic's Avatar
thanks mark, im thinking its the fan tho. i didnt hear it turn on at all. i took the jeep all 3 hours home last night. ran just fine in the cool evening hours, but it did heat back up sitting at stop lights
Old Jul 19, 2010 | 09:41 AM
bcrez's Avatar
If your jeep is an 08 this was covered under a factory recall. ask ur dealer about it.
jeep has been golden, up until last night...
had been riding around alittle and went to pick a buddy up, went to back out and the temp. gauge went nuts. was way past hot and i could hear everything boiling, so i shut it off right there in the road. waited a while with it, went back to normal temp and the battery light starts turning on. i have no idea why. everything has been working perfectly til now. i checked when it overheated, no leaks. all fluids are full, everything is fine. what could it be? im supposed to be taking my girlfriend home tonight for work tmrw. its a 3 hours drive from fripp island to augusta, and im not sure if the jeep is such a safe bet...can u guys think of what it might be? thanks for the help!
Old Jul 19, 2010 | 12:02 PM
LaxAHolic's Avatar
shes an 07...
im not really sure what the problem is..
