LED halo headlight confusion
i bought a set of LED headlights with halos in hopes of seeing better at night. i didn't hook up the halos until recently. my issue is that they work as advertised (turning on white halos while jeeps is running) however they are red instead of amber when i use my hazards or turn signals. has anyone wired the halos so that they can control the color of the halo? i wired them to a switch but it only turns the white on and off.
So what model of light did you order?
I have a set with the white halos that blink amber when the signal is on. I don't think anyone will be able to give you any real assistance without knowing the model of the light you installed. Some have color control but most are only a single color. It is likely that if your lights are red that they will only be red.
