Led lights
Old Sep 15, 2013 | 03:48 PM
jabarnett's Avatar
Default Led lights
Dumb question but I'm new to this so ill ask anyways . I just bought some led lights but I need a 12 v power where would be the best place to get it from without messing up anything ?
Old Sep 15, 2013 | 03:53 PM
RavenZ33's Avatar
What is the purpose of the lights? If auxiliary style lights for the exterior, I would run them directly to the battery with an internal switch to control them.
For the interior to light up the foot wells, I ran mine to my mirror adjuster knob in the lower dash bc it can be dimmed with the rest of the interior lights.
Old Sep 15, 2013 | 04:24 PM
jabarnett's Avatar
Wow good info and no relays
Old Sep 15, 2013 | 08:12 PM
Jersey_Devil's Avatar
No u will still need a basic Aux relay that u can get at any auto parts store & an in line fuse
Old Sep 15, 2013 | 08:16 PM
karls's Avatar
And how many/ what size are the lights? If it's something like a footwell light then you don't need a relay since it doesn't add that much draw to the system. If it's a 50" bar then use a relay and a fuse.
Details......
Sent from my DROID4 using Tapatalk 4
Old Sep 15, 2013 | 08:28 PM
k0260's Avatar
I tapped my foot well led strips into the dome light wire. Clean and painless.
Old Sep 15, 2013 | 09:51 PM
jabarnett's Avatar
It's the waterproof leds string that I bought from eBay very bright but just asking how to hook up , don't sound to hard , I do want to do the dome light so they go on when the dome lights do seems cool and one little strip under hood ,
Old Sep 15, 2013 | 10:09 PM
jabarnett's Avatar
They are the water proof leds string that u can get from ebay they seem easy . I want to do the dome one sounds easy and cool to do and would like to put a string under the hood for light
Old Sep 16, 2013 | 03:50 PM
RavenZ33's Avatar
My footwell lights that I installed, I wired them directly into the control switch for my mirrors. Which makes them dimmable with the remainder of the lights. However a light bar I would run directly to the battery and run a control switch inside the cab. Wiring it directly to the battery you don't need to worry about flickering.
Old Sep 16, 2013 | 07:00 PM
951JEEP's Avatar
No. I definitely would not advise to run them directly to that battery with a single switch to control them. You need to install a 12v relay to wire them appropriately. Depending on the wire used and load on the circuit, wiring them directly to the battery could create excessive heat and cause a potential fire.
