lift questions
Old Aug 22, 2007 | 05:11 PM
ncaljp's Avatar
Default lift questions
just brought home a 2007 2 dr X. my question after reading many posts is how to achieve the lift i want. i will be running 33-12.50 tires. i really like the 2.5 BB lift but want to make sure it sets level. so i am thinking about the 1" spacers included with the lift. i have the lifetime warranty and if there is ever a problem i can go back to stock easily. is it a good idea to stack spacers?? all your help is appreciated.
Old Sep 5, 2007 | 03:12 AM
Jeep 007's Avatar
Well,
I have the Jeep dealers over here install MT Wheels and Tires on the new 2dr & 4dr Sahara from the show room floor.
They are running 17X9 & 33" 12.5 on the Stock set up, and i have seen no rubbing issue's so far.
Hope that helps
Old Sep 5, 2007 | 05:18 AM
wayoflife's Avatar
JK-Forum Founder
If you're going to be stacking just the one extra spacer, you should be fine. Or, you might also want to consider a BB kit like Full Traction or Rubicon Express makes as they are designed to level out your ride.
