Light ESP and ABS in my jeep JK
All good advice.
1. Make sure your battery connections are tight. There should not be any accessories attached to the nut that is closest to the battery terminal. This is a cam nut and tightens the connection. If something is on that nut the connection can be bad.
2. Make sure your steering wheel is straight when the wheels are straight. If not, use the drag link to adjust. It's a 10 minute job.
3. Check the connections to the wheel speed sensors. Make sure the connector is plugged all the way in and there are no broken wires. This is especially true if you flexed your Jeep recently or installed a coil lift.
4. Post up when it is fixed so other members can learn from it.
