mopar update
Old Apr 12, 2009 | 04:54 AM
sgt rock's Avatar
Default mopar update
Here's a list of Jeep factory-authorized parts that let you turn your Wrangler X into a facsimile of the Rubicon. (Unfortunately, if you have to pay someone to install the parts, it's cheaper to buy the Rubicon already assembled from your local Jeep dealer.)
kind of neat to see the mopar cat'
http://www.mo-pod.com/pdf/09_Perform...log-120908.pdf big 27 meg file jeep items start at page 250 = was surprised that they had gauge pods for tj's but not jk????
source: http://www.mopar.com/performance/trail/index.html
Sway Bar Disconnect
Sway Bar with Power Disconnect
Part Number: 82210218
$1,410.00
Skid Plate for electronic sway bar disconnect
Part Number: 82210401
$246.00
Body armor
Rock Rails
Part Number: 82210586
$317.00
Bumper and winch
Off-Road Front Bumper w/ winch mount
Part Number: 82209740AD
$587.00
Warn 9.5ti Thermometric 9,500-lb pull Winches
Part Number: 82209325AB
$1,510.00
Off-Road Rear Bumper
Part Number: 82211718
$557.00
Spare Tire Carrier, up to 37" tire
Part Number: 82211832
Use with Off Road Rear Bumper 82211718
$502.00
Rubicon Axles
Dana 44 Front axle for Rubicon
4.10 gears, locking differential, no brakes
Part No. P5155252
$2650
Dana 44 Rear axle for Rubicon
4.10 Ratio, Locking Differential
P5153826AB
$1640
Suspension kits
2 inch Lift Kit
uses longer springs, brackets, and shocks
makes room for 35" tires
works with Electronic Stability Program (ESP)
stock wheels and tires can be used
Part Number: P5155207
$1385
Long arm 4.5 inch lift kit
including long-arm control arms, u-joint drive shafts, Bilstein shocks
makes enough room for 37" tires
Part Number: P5155075
$4650
Axles for J8 Military vehicle
Mopar Jeep JK Rear Locked Dana 60 Axle
Part Number: P5155083
includes limited slip diff, 5 on 5.5 inch hubs, leaf spring mounts
disc brakes from Dodge pickup, 13.8 inch rotors
needs 17 inch rims to clear the rotors ( need to confirm)
$2995 at Quadratec
a version with rear locker is available, too, and $200 cheaper
Mopar Military Spec Front Dana 44 Axle Assembly
front axle tube is 25% thicker than standard Dana 44
includes Dodge truck 13" rotors and brakes, 5 on 5.5" hubs
open differential, 4.10 to 1 gears
Part No: P5155084
$4495 at Quadratec
Engine for J8 military vehicle
VM Motori 2.8L four cylinder turbo diesel
174 hp and 339 ft-lbs
5 speed automatic transmission
planned, maybe only available through AEV
no part number or price yet
Air intake for J8 military vehicle
opening mounted on the hood, includes better air filter
planned, no part number or price yet
Old Apr 12, 2009 | 09:07 AM
09rubicon's Avatar
Actually after looking through that I think I am more interested in the Power Wagon axles!!!!
