New Jk.
Old Dec 8, 2007 | 09:13 PM
AZchris's Avatar
Default New Jk.
My wife and I are going back and forth between buying a new JK or a 2005 Grand Cherokee. How does the reliability seem to be on the JK? Over that the GC forum there seems to be a ton of problems with the Cherokees (diffs, trannys), but the JK is build from the same company so are you guys having these problems as well?
We are wanting a long lasting dependable vehicle, do you think the JK will be a long life vehicle?
Thanks
Old Dec 8, 2007 | 10:22 PM
IndianaJK's Avatar
You will get the lifetime powertrain warranty on the New JK and the 3/36 BB.
The used 05 GC wouldn't get any warranty would it?
Old Dec 9, 2007 | 02:11 AM
pearl-drum-man's Avatar
Yeah, from a warranty standpoint you'd be much better off with the new JK. As for problems, the JK has had it's share of gremlins being a new vehicle, but overall the drivetrain seems to be very stout, so it should hold up well long-term.
Old Dec 9, 2007 | 06:31 AM
scootrrydr's Avatar
Default Buy the JK
Thanks
Buy the JK. U stated a "new Jk". That has the lifetime powertrain warranty. The 2005 won't. If you want a long lasting vehicle, the JK is your best option. Just don't buy it for the gas mile age.
Old Dec 9, 2007 | 07:27 AM
whatroads's Avatar
I had an 02 Grand Cherokee LTD. 4.7 V8, 3.73 gear, front and rear vari-lock axles. It was a good vehicle. I still prefer my new JK. There are more build options for the JK. I had a set of Kevin Fell's rock rails that extended out from the body about 4 inches. Due to the rounded body I still could not use my Hi-Lift. IMHO the JK has about the same interior room as the GC.
In addition to the rock rails, I added a 2.5 inch BB and 32 inch tires. The Vari-lock LSD like system worked pretty well. Just not as good as real lockers. Lower after market R&P gears were non-existant at the time I owned mine.
I finally traded it in on a 3/4T Dodge truck when I noticed cracks starting to appear on the body. These were noticable when you lifted the rear hatch. I am almost sure they were caused by the Unibody twisting as I was off roading, (it's a Jeep isn't it?)
Some of the positive sides for the JK: Mine came with 32 inch tires. Back D44 is stronger than the GC aluminum D44. Front D30 HP on the JK is stronger than the GC D30. JK has a body on frame vs GC Unibody
Last, but not least, I believe the 05 GC has an IFS front. I am dead set against IFS for any off road vehicle
Old Dec 9, 2007 | 08:10 AM
AZchris's Avatar
Thanks guys,
I am also wanting to get opinions from some hard cord Jeep guys.
Do you think the JK will hold up like some of the older Jeeps. I mean there are old CJs running strong with 200,000 miles. Do you think this model has the potential for that kind of longevity?
Old Dec 9, 2007 | 10:40 AM
CIJeep's Avatar
Thanks guys,
If you're waffling then make sure you're comparing the 4dr Jeep.
As to 200K miles? that could be chewed up in 3 yrs depending on your driving.
But I would say yes, for other than the electronics. The electronics is the weak link in any vehicle and I have yet to see electronic replacements for older vehicles of any make.
Old Dec 9, 2007 | 10:55 AM
wayland1985's Avatar
The engine will go for millions of miles, if you take care of it. And if it doesn't, and you were taking care of it, you have a lifetime warranty (assuming you're buying a NEW JK).
But, if you're not going to wave, get the cherokee
Old Dec 10, 2007 | 02:12 PM
BillyJack's Avatar
I just purchased my JK (4 door Rubicon, Auto, 4.10) and couldn't be happier. I also own a 2002 Grand Cherokee and love it. I have owned a 96 Grand, 99 TJ, 89 YJ and 84 Cherokee Chief. Every Jeep I've owned has gone over 130k miles and ran great. I don't think the JK is going to be any different.
The JK and the Grand Cherokee are 2 completely different vehicles. One gives you a luxury like, quiet, softer ride and the other (JK) is stiffer, louder (with the soft top) and in my opinion, a heck of a lot more fun!
Also, you will be more likely to have your JK as your computer wallpaper! Have fun out there and good luck with making a decision.
.....(get the JK!)
Old Dec 10, 2007 | 03:17 PM
Ctimrun's Avatar
Get the JK! The JK's engine is the same engine that's in a chrysler minivan that we had that had over 160,000 miles and was still going strong. Plus the JK will do this...
