New JKU owner need help
Old Aug 21, 2016 | 01:49 PM
Alkymixr's Avatar
Default New JKU owner need help
I am the new owner of a 08 Sahara got the jeep in good condition with low miles 70k (IMO). It was originally a "big country " and from what I can tell that was just a dealer installed lift and wheels..
I have addressed the main maintenance that I've been able to find on this and other forums the
Quick list .
Plugs wires ,Throttle body removed and cleaned,Swapped all fluids to syn,Thermostat and gaskets,Serpentine belt.
Issues I can find answers for The pin in door hinge spins not allowing me to remove door.
I tried all remedying I could find and ended up removing the hinge from the jeep. Works to get door off but still can't get the hinge off the pin...any help would be great!
I have attempted twice to pasti dip the chrome wheels.
Degreased and cleaned first , it peels after a day or two... Removed and cleaned with cleaner and a acetone rag ... Still peels off ... Anyone else run into this problem? I don't like the chrome but also don't want to sand them up just to pasti dip....
Any help would be great thanks !
Old Aug 21, 2016 | 07:09 PM
JK Pleepleus's Avatar
Since you already pulled the hinges off the jeep, ( i'm guessing off the body) remove them from the doors, and then soak them in a tub of (insert your favorite solvent here) and let sit. Doors that have never been off take a bit because the pins are sitting in the inserts and have rusted in. Aftermarket makes nylon inserts, I just lubed the hell out of mine and now they come off easy. You might have a hard time to re-align the hinges back on the body once you have everything loosened. Worst case scenario remove all hinges and buy new ones and bolt them on.
Old Aug 22, 2016 | 03:51 AM
Alkymixr's Avatar
I was able to work all but 2 hinges off the doors , one these two the pin actually spins rather than the hinge .... I've seen replacement pins so I'm assuming I can drive the whole pin out ?
Totally plan on installing the Derlin bushings .. They seem to have the best reviews !
I was worried about the door lining up but it was fairly easy to get the hinges on so they close and seal correctly ,
Old Aug 22, 2016 | 05:56 AM
Gman*2007's Avatar
Welcome to the forum.
Old Aug 22, 2016 | 08:21 AM
Alkymixr's Avatar
Thanks
