Oil change info.
If you drive under the following conditions (ie: everyone I know)
- Day or night temperatures below 32 degrees
- Stop and go driving
- Excessive Engine Idling
- Driving in Dusty Conditions
- Short trips less than 10 miles
- More than 50% of your driving is sustained high speeds during hot weather, above 90 degrees
You should change your oil every 3k miles.
An interesting side note is that the owners manual for my 2010 does not have a schedue A and schedule B. It just reccomends oil changes every 6k miles. This is very strange since there is no difference in the engine. Stupid Chrysler!
If you have any kind of warranty, I would do it every 3k and keep your records.
just changed my oil today...however... a jeep is supposed to get 6 quarts when you change the oil. i drained the engine...but only pulled out 2 and 1/3 quarts. thats not good =(
They are now using Mobil 1 oil. This is what I have been using for the last 25 years in all of my cars or suv, and never had a problem. I have had cars with over 100,000 mile. That oil would last you up to 100,000 miles but what goes bad is the oils filters. I just had a oil change at the dealer to day. The next time I go back would be in about 8 to 10,000 mile.
Your Jeep is one of a few that use some oil. If I were you I would check the oil level weekly until I get comfortable with the consumption rate.
You bought used and probably have no warranty left, and if you do, Jeep will find a way of voiding it, take care of your engine.
I would also go with a thicker oil, like 5W30 instead of 20.
How many miles your Jeep has?
