Oil consumption
Old Jul 8, 2012 | 01:20 AM
spartan99's Avatar
I added a quart of heavy weight and it stopped losing oil.
Old Jul 8, 2012 | 07:25 AM
Ryan0260's Avatar
Originally Posted by Mark73
Yah I tried 5w30 and no change that I could tell . And most of my other vehicles went through around a liter or so at the most between oil changes . Always change at 5000 Kms . I'd really just like to know where it's going ? Past rings ? No smoke out tailpipe ? Dealer is changing my cats next week cause they chatter - rattle like crazy . Makes me wonder why ? I'm no mechanic although I've been fixing and servicing my own cars and trucks for 25 years and have a general concept of how engines work. But not sure what's going on here ? And not going drives me crazy!!! Just the way I am have to figure things out and try to fix it , Cheers :-)
Yep past the rings and straight into the cat. Make sure when they take it off that you get to look inside it. I imagine it is clogged with oil
Old Jul 8, 2012 | 09:45 AM
TINMAN080's Avatar
the honeycomb in his cats have cracked and are rattling internally. Usually a lean engine condition will cause this. You guys try 10W30 dino oil for a couple of changes, you will have little to no consumption and a quieter engine.
Old Nov 22, 2012 | 03:40 PM
scicero1's Avatar
Default Lucas Oil Stabilizer
ever since I added this, I seem to burn less oil
Old Nov 22, 2012 | 05:13 PM
Jkfamilycrawler's Avatar
I do think he is probably telling you the truth about mopar spec. I am a tech for a Honda dealer and Honda's spec is a quart every 1,000 miles. In my opinion there is an issue if your burning that much oil but that is what the manufacturer says is ok. I think it is to cut down on warranty repairs. They will not cover a repair under power train warranty unless it uses more than that. Hope this is helpful!
Old Nov 23, 2012 | 06:52 PM
SLVR07's Avatar
I have a 2007 and maybe put 1/2 quart in at about 2,500 mi. I change it every 3,000 miles an use factory recommended valvoline.
Old Nov 24, 2012 | 08:44 AM
Ryan0260's Avatar
Exactly. It is due to sloppy tolerances when building, so they say that to leave a huge margin of error. Its ridiculous
Old Dec 1, 2012 | 08:04 AM
Topjimmy's Avatar
Default Are there any trade offs or issues
with going with a thicker oil?
I have no clue when it comes to this but adding oil every week or so is becoming quite a PITA. specially now that it is getting colder.
Old Dec 1, 2012 | 09:21 AM
backwoodjk's Avatar
Like Tinman said, 10w 30. I am using it, works great, burning no oil.
Old Dec 1, 2012 | 05:08 PM
red2010rubi's Avatar
My co-worker had this issue with his 2009 JKU and the dealership ran a dye in his oil so that they could see if it was leaking in the engine anywhere under black light and sure enough it was. They fixed it under warranty.
