Part for jku 13 soft top
Old Sep 27, 2014 | 06:26 AM
possingk's Avatar
Default Part for jku 13 soft top
Does anyone know what this piece is called or the part number? This is driver I need passenger. Click image for larger version
ID:	577449Click image for larger version
Old Sep 27, 2014 | 07:02 AM
AngryRedBird's Avatar
This is part of the bow assembly.. mainly the snug tight that the tube frame fits in or that the part needed rest into the door surrounds.. Also, is it just the molded channel part of the whole knuckle area thats broken or missing?.. Could even be the sunrider pivot knuckle assembly..
Old Sep 27, 2014 | 08:18 AM
possingk's Avatar
Thanks angryredbird I looked at the piece in the link but my 13 doesn't have a part that goes into the bow. It attaches with screws from the top
Old Sep 27, 2014 | 09:54 AM
I'm assuming it's the extended U channel part that you're looking for.. so it's unclear if they sell just the u channel..and you have to buy a full bow or the part in the link supplied and remove the part you actually need..
One thing that would help, is if you actually pointed out (with a red arrow) what part you're searching for.. again I'm under the assumption it's the u channel..
Sadly, the 2 door version does not have this part.. or I would have offered what ever parts I have left..
Old Sep 27, 2014 | 04:36 PM
possingk's Avatar
AngryRedBird, I believe you are correct, it is the extended channel piece, I also took your advice and added an arrow.Click image for larger version
Old Sep 28, 2014 | 02:22 PM
You have a couple of options..
Either
Order the pivot knuckle as posted in the link above.. to get the part you need.
or
Hope to find someone with a spare soft top that's willing to split up the parts/hardware from the frame in order for you to get what you need..
Again I had the frame with these parts.. But I thought I removed them and either gave them away or sold them.. It's prob easier to just order the pivot points from a major retailer.. and just replace the whole knuckle assembly.
