perfect spool???
Old Feb 5, 2012 | 11:20 AM
samhardy2008's Avatar
Default perfect spool???
Ok so last night im driving home and notice a Ford explorer is high centered on a culvert...I go to engage free spool and try to pull it and the bitch was stuck,and to press the out button and feed it out that way....what's a good fix to make sure this crap dosent keep happening??? And no im not buying a synthetic line yet....don't have those kind of dollhairs at the moment lol
Old Feb 5, 2012 | 11:21 AM
I mean it fed back into the winch fine and pulled the dude out fine but yeah
Old Feb 5, 2012 | 11:29 AM
No the free spool engaged fine its just I couldn't pull the winch line out by hand because it wad like tangled....but idk how to do the beautiful perfect spool I see so many with lol
Old Feb 5, 2012 | 11:36 AM
jksteve89's Avatar
Keep tension on it when you are reeling it in.
Old Feb 5, 2012 | 11:37 AM
gunbo75's Avatar
Was the cable crossed over each other That's the only thing I can think of.
when you got your winch did you spool your cable under load first .
good luck
Old Feb 5, 2012 | 11:44 AM
Radioman's Avatar
Veteran: Navy
You need to unspool the line until you have just 4 or 5 wraps on the drum left. Hook up to another vehicle or strong anchor point and reel in the cable while riding the brakes of your Jeep. I usually have a friend steer while I ensure the cable wraps on the drum neatly with the cable next to the previous wrap. This is done by the friend steering the Jeep so the line is straight.
If you don't wrap the line on with a load, it will sink into the lower wraps and damage the cable and be very hard to unwind.
Old Feb 5, 2012 | 02:43 PM
ahh thanks yall and no sadly i decided to just skip the first load thing...guess that will teach me to not follow directions
Old Feb 5, 2012 | 04:17 PM
dp7197's Avatar
Your cable "cleaved" it's way into the lower wraps which made it hard to pull out. The easiest way to prevent this from happening is to always pull out as much cable as you can for every pull. You must always leave at least 5 wraps of wire rope on the drum (10 for synthetic).
Besides making it harder for the cable to work its way into other layers (there are none), you will always be using your winch at it's rated capacity - under perfect conditions.
If you always do this, there would be no need to dress your cable under tension. If you plan on only pulling out 45(?) Feet of cable each time you winch, you had better make sure your cable is tight, or plan on having trouble if your cable cleaved in. Also plan on your winch being at up to half it's pulling capacity.
Old Feb 6, 2012 | 11:38 AM
Ok so at work today I pulled our golfcart around and a guy I work with helped me put a 200 pound industrial tire in the back of it and I spooled the winch out till the last layer and hooked up to golfcart and pulled it uphill looks pretty damn good if u ask me...golfcart ways round 900 empty and guy I work with was sitting in it and the tire was on the back and he weighs bout 240 and tire was bout 200 so I think it wad enough weight....im happy with it....didn't "cleave"
