Plastic dip question
Old Feb 20, 2014 | 05:36 AM
JK_Jeff's Avatar
Default Plastic dip question
I want to plastic dip my rims any suggestions on plastic dip and how to apply?
Old Feb 20, 2014 | 05:48 AM
OH9JK's Avatar
JK-Forum Ambassador
It is very easy...clean well, mask off areas you don't want overspray on and apply a few light coats. Your local home centers typically carry it in the spray paint aisle.
There are several how-to videos on YouTube.
Old Feb 20, 2014 | 06:11 AM
JK_Jeff's Avatar
Ok sounds good
Old Feb 20, 2014 | 06:13 AM
MyJeepNS's Avatar
I took my wheel off so I didn't spray the brakes and light coats works best. I've had mine for about 2 years and so far no peeling or anything
Old Feb 22, 2014 | 04:31 AM
JK_Jeff's Avatar
Did you do your lug nuts too?
Old Feb 22, 2014 | 06:10 AM
MTMxRubi's Avatar
Not a good idea. You will tear it up when you torque the lugs. Get a set of black gorilla spline lug nuts.
Old Feb 22, 2014 | 06:51 AM
JK_Jeff's Avatar
Originally Posted by MTMxRubi
Not a good idea. You will tear it up when you torque the lugs. Get a set of black gorilla spline lug nuts. Sent from my iPhone using JK-Forum
Yeah I was wondering if that would happen. Guess I'll try to find some. Thanks
Old Feb 22, 2014 | 06:56 AM
JKBANDIT55's Avatar
Here are mine. I took the wheels off, the center caps as well and threw about 5 coats on each wheel.
After about 3 trail runs rock rash started peeling the paint off on the outer part of the rim. So I just peeled the outer ring off. For now I just re- spray the rock rash when it starts getting bad and it bonds and blends well. Which is good because you dont have to peel it all off just to re paint.
Like I said for now this will do, but if you do a lot of wheeling it will scrape and start peeling.
Old Feb 22, 2014 | 07:10 AM
JK_Jeff's Avatar
Originally Posted by JKBANDIT55
Here are mine. I took the wheels off, the center caps as well and threw about 5 coats on each wheel. After about 3 trail runs rock rash started peeling the paint off on the outer part of the rim. So I just peeled the outer ring off. For now I just re- spray the rock rash when it starts getting bad and it bonds and blends well. Which is good because you dont have to peel it all off just to re paint. Like I said for now this will do, but if you do a lot of wheeling it will scrape and start peeling. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=532616"/>
Nice rig. Actually looks good without the outer ring.
Old Feb 22, 2014 | 07:33 AM
MTMxRubi's Avatar
Quadratec has a set for JKs that includes 23 to cover the spare as well.
